Sponsored by: CARiD
Charging problem
Old Jan 6, 2006 | 12:03 PM
will69camaro's Avatar
Sex On Wheels
Ok i'll give that a test later today!
Thanks,
William
Old Jan 6, 2006 | 08:26 PM
CashMoney's Avatar
Uh I'm a newbie but wouldn't a stretched serpentine belt or a faulty tensioner cause the same problemss?
Old Jan 6, 2006 | 11:41 PM
Sex On Wheels
Tensioner was checked during one of the many times i've had the belt off and the belt has less than 200 miles on it, i hope it's still good.
William
Old Jan 15, 2010 | 09:57 PM
T/A Tom's Avatar
I'm having the same issue with my 2000 WS6. I drive it every couple of months (but start it every week) and last time I took it for a spin the voltage was low then popped back up after a couple of miles. Now it won't come up at all. I was going to replace the alternator tomorrow but now this has me wondering if I should
Old Jan 16, 2010 | 12:49 AM
vikingramair's Avatar
Check the excitor wire, the wire that plugs into the top of the alternator. It supposed to tell the alternator when to charge. Could be broke, mine was. It´s a red thin one.
Old Jan 18, 2010 | 10:07 PM
bigred122's Avatar
I was having a fluctuating voltmeter bouncing between 13 and 14 volts, and so I replaced the battery thinking it was on its way out. The problem didn't get any better with a new battery, so I started thinking about the alternator.
After reading the above post, I pulled off the top connector tonight to inspect the excitor wire and connection, and plugged it back in, and now my problem is gone. The wire wasn't broken, but I think it just had a bad/dirty connection, and just unplugging it and plugging it back in was enough to make a more solid electrical connection on the pin. So I think I have fingered the problem. Thanks for pointing me in this direction, you saved me buying a new alternator.
Old Jan 19, 2010 | 11:22 AM
