Sponsored by: CARiD
Camaro DRL
Old Dec 21, 2005 | 01:46 PM
corvettelover's Avatar
Default Camaro DRL
Not sure if this is in the right place, so I appoligize. My passanger side DRL on my 2000 Camaro is dimmer than the dirvers side. Has anyone else experinced this? I wasn't able to get the lens out of the car, but I did use water and a paper towel to clean the inside of it, didn't fix it. I also replaced the bulb, but still seems dim. Please help me with this....it bugs the hell out of me
Old Dec 21, 2005 | 01:49 PM
Roarin_8's Avatar
Check the voltage. Any specific electrical drain on the car?
Old Dec 21, 2005 | 02:00 PM
No drain at all. I've had the car for 2 years, never changed the battery. Has started up fine since day one. What should the voltage read?
Old Dec 21, 2005 | 04:19 PM
Roarin_8's Avatar
Check the electrical section of the forum and see what the guys say there. Electrical is a nightmare for me, yet my uncle is an electrician, go figure. Good luck.
Old Dec 25, 2005 | 05:44 PM
venom346's Avatar
I remember i replaced the bulb on my 99 z28 with a newer clear one. I later noticed it was dimmer than the other. I eventually changed that bulb back to one that was yellow in color and my issue was resolved..
