Sponsored by: CARiD
Headlights Trouble??
Old Dec 24, 2005 | 02:09 PM
Jeff Smith's Avatar
Default Headlights Trouble??
I have 2003 DuraMax Diesel 2500HD, had wrecked at front end and reconditioned body.
The headlamp (dimmer) at driver’s side, strong bright and passenger side, weak low. When I turn high beam switch is same as dimmer headlights.
I found the two grounds (-) attached onto frame beside at under front left bumper.
:bang :What wrong with it?
Have you experinced with that situation? I need your help to solve with it.
Thanks for feeding back...I appreciate it
Dusty
Old Dec 24, 2005 | 08:32 PM
gwj's Avatar
gwj
From: Live Oak, FL - in the woods where the creatures lurk.
You might check out the associated truck site:
http://www.performancetrucks.net/forums/
Good luck.
gwj
