Trans Am headlamp problem..please help.
thanx in advance.
If it doesn't work, I would check the headlight connector. To find the connector just follow the wires from the headlight motor and headlights. It's the first connector you run into. Anyway, open the connector and check if the plugs are making contact. The plugs tend to fry up sometimes.
If this is the problem then cut the wires that connect to each other and make a straight connection using one of those connectors from your local auto parts store.
From my experience it's always the motor itself that has the problem or the gear or the connector. Good luck with it.
