Sponsored by: CARiD
headlight TSBs?
Old Dec 27, 2005 | 12:58 PM
TNTramair's Avatar
Default where can i find.........
TSB and bulletin information for our cars...i thought we had a section here on the board about it but either im retarded and cant find it or its not up anymore...thanks
Old Dec 27, 2005 | 01:36 PM
2K2WS6TA's Avatar
You can get some info here
http://www-odi.nhtsa.dot.gov/cars/pr.../tsbsearch.cfm
It's not very complete (unless you pay for the research) but it does give the number of the tsb
Old Dec 27, 2005 | 02:16 PM
Fogle07's Avatar
what you looking for? i might can look it up on alldata
Old Dec 27, 2005 | 03:50 PM
TNTramair's Avatar
something pertaining to the headlamps. the headlights still work but the motor to pop it up isnt coming on at all...and its only the right side (pass.) driverside works fine...it has nothing to do with gear issue cause the motor isnt even coming on...and i did check the fuse, they are fine. just wondering if theres anything perticuler i can should look for to cut down my diag time. thanx again.
BTW...i checked nhtsa and no go there.
