Sponsored by: CARiD
power window problem
Old Dec 31, 2005 | 05:19 PM
travSS01's Avatar
Default power window problem
OK fellas , i just installed 25th an. kenwood deck with new component system and new 6-1/2" speakers- i ran all new wires bypassed the factory amp (had to take door panels off and i disconnected the switches) i tried the lock switch on the passenger side works fine and didnt think to check the window....i reinstalled everything and and all speakers and deck work fine drivers side window and lock works and as before passenger lock works fine but the passenger window will not from its switch or from the driver's side?/? im assuming that if a fuse blew niether the driver or passg. would work, what could this be,.... mabey the window went offtrack when reinstalling the panel ? the window makes no noise at all when trying to activate it??? i just thought id ask to see if anyone has had the happen when fooling around with panels
Old Jan 1, 2006 | 02:04 PM
WhiteRhino's Avatar
The power window wires run behind your door speakers and share the same loom thru the door to the inside of the car.I would pull the panel back off and check the wires going from the window motor to the door.Maybe you damaged one of them.
I'm not sure if the windows are fused differently,but I would check the fuses just in case.It could be a relay as well.
If the motor is good it can only be a couple of things,which most I listed above.
