Sponsored by: CARiD
bucking when put in to drive or reverse
Old Jan 4, 2006 | 10:58 AM
98redorangeta's Avatar
Default bucking when put in to drive or reverse
I think that this is generaly a symtom of the backlash in the rearend but the problem is it dosent happen all the time and some times it is worse than others. I also noticed one day when i had my maf plugged back in that i didnt occur once that day. The maf part maby should be in another section i just want to get some opinions.
Old Jan 4, 2006 | 05:27 PM
SgtB's Avatar
have you checked your tranny fluid level??
Old Jan 5, 2006 | 11:16 AM
No i didnt think about tranny fluid because i was kind of convinced it was a backlash problem I am getting redy to put a shift kit and tc in the car so it will be getting a fluid change when that happens. Hopfully that will fix it.
Old Jan 5, 2006 | 03:17 PM
SgtB's Avatar
check your trans fluid first
backlash shouldn't cause that
