Oil Pressure?
well the other day, for some reason the oil pressure was jumping probably from 45 and going back to 50 within seconds over and over again until i got on the gas and i havent seen it do it since, like you have your blinker on and your alternator needle kinda gets a little tweaky... what would this mean in your opinion?
As for the fluctuation I'm not really sure. I suppose its possilbe that you have a bad oil pressure sensor/sending unit. Try a search in addition to this thread.
50PSI at idle and warm seems high as well.
ummm i put in mobile 1 sinthetic, although i was going to switch to a different kind, due to recomendations on this site... but i forget the brand
If the pressure is erratic like that, it could just be a bad gauge or sender. Perhaps double checking it against a different gauge (known to be accurate)?
