Sponsored by: CARiD
whine on decel
Old Jan 8, 2006 | 06:05 AM
darbydarby's Avatar
Default whine on decel
did a search,most of stuff was on 12 bolt rear ends.....
car sounds fine during acceleration,out of nowhere im hearing a loud whine when letting off the gas in gear,when its in neutral(6 speed) rolling the same speed I hear absolutely nothing. I have not been to the track or been doing any irregular driving. have had no rear end or tranny problems,although I am already saving for a 9" so I can eventually go to the track.
what Im asking is if it is the tranny or rear, and how long should I be looking for it to last?
If you need any other info to give an accurate answer let me know, and thanks for the help.
Old Jan 8, 2006 | 06:33 AM
N3V3RL8T's Avatar
Sounds to me like the rear... And how do you not do any irregular driving with 525 rwhp?!?!
Old Jan 8, 2006 | 06:42 PM
darbydarby's Avatar
Looks like the third 10 bolt rear in the camaro has finally crapped out.
it started leaking from the front of the rear on the driveshaft(also making a loud whining on decel),was told it was a pinion seal.went to replace the seal and when I grabbed the driveshaft it moved around a lot,turns out the pinion nut was not even finger tight.......took all that off happily thinking that it was a simple problem to solve,grabbed the pinion shaft coming from the rear and it moved a lot....after walking to look at the two broke rears i have I see that this is not a good thing,looks like the bearings are bad......(is there an easy way to replace the outer one?)
so I have no choice but to put the car up on jackstands and .......
A. have it rebuilt which will cost a small fortune(an easy grand im sure)
B. struggle to find a 4th piece of crap 10 bolt thatll cost 3-400 bucks thatll last anywhere from a day to a year.
OR.........................
C. wake up early in the morning and call moser for my 9" housing and start browsing ebay for my 4.33 detroit locker chunk.....
