Sponsored by: CARiD
Changing DRL Bulb
Old Jan 9, 2006 | 11:33 AM
DrewSG's Avatar
Default Changing DRL Bulb
Do I have to plug out the battery? If so, which terminal would I have to plug out, and is it safe to do with my headlights popped up (I need them up to reach down to the bulb)?
Old Jan 9, 2006 | 12:30 PM
Flaminchiten67's Avatar
Plug out the battery? you mean disconnect? It shouldn't have to be disconnected, just do it with the car turned off. It shoiuld be fine to do with your head lights up also. I change mine from underneath the car with the little access flap its way easy, two 10mm bolts and reach up get the harness twist it and pop it out then remove bulb and pop in new one.
