Sponsored by: CARiD
How much play should the driveshaft have?
Old Jan 10, 2006 | 12:21 AM
tappy's Avatar
Default How much play should the driveshaft have?
How much play should my driveshaft have i have a 01 TA 6speed and it makes a knocking noise 1000 to 1500 in every gear .I jacked it up grabbed driveshaft behind joint in the front and could move it about a quater of a inch up and down the dealer said it is normal play in the driveshaft and that the sound is normal although i cant see how a thumping noise that sounds like a out of balanced tire that goes away when i let off the gas can be normal?
Old Jan 10, 2006 | 10:39 AM
bolton98TA's Avatar
i have the same thump problem but it just does it in 1st and 2ed sometimes. i would also like to know what is causing this.
Old Jan 10, 2006 | 10:29 PM
ZeeVert's Avatar
A quarter inch sounds like a lot to me.
Old Jan 13, 2006 | 03:08 AM
BULLET99Z28's Avatar
depends on if the play is between the tranny splines and the drive shaft splines, try and isolate the driveshaft so that u can check the ujoints,normally ujoints wil vibrate at speed,not always, if you have a decent amount of miles, check the u joints or replace them. output shaft splines could be wore, but those are generally heat treated to be hard. if the ujoints have play,replace them. u couldalso be hearing normal gear noise< my tranny gears are more noticable since the poly mount,manuals are not as quiet as autos.PS-pull the driveshaft out and check the condition of the splines
Old Jan 13, 2006 | 09:32 AM
speedybreesy's Avatar
Im on a ranch!
sounds like u-joints to me.
