Start up after a year
Thanks for any help,
Joshua
but not the easy way.
If you can activate the pump at will you can keep
dumping fresh fuel in and flush the system (with
the fuel line disconnected).
Or, my way, just see if it will crank & run. Add some
injector cleaner and add a fresh tank of gas and run the
$hit out of it after some careful warm up driving.
Then consider an oil change after a bit.
After that you may have to change the fuel filter & plugs,
maybe shoot some TB cleaner in (at the TB, not before the
MAF).
HTH.
Just exactly where are you getting your car back from?
If it's "NONYA" then that's cool.
gwj
