Sponsored by: CARiD
do you use oil additive?
Old Jan 21, 2006 | 08:37 PM
THE LAST Z's Avatar
Default do you use oil additive?
Just what it sais. for example: prolong. stuff like that. Does it help?
Old Jan 22, 2006 | 06:44 AM
Bill Bowling's Avatar
Talking
Stay away from it. Just change your oil often with German Castrol 0W30 and use K&N #2006 filter. That is what I do. Of course there are other oils and filters.
Bill
Old Jan 22, 2006 | 06:52 AM
MeentSS02's Avatar
Kleeborp the Moderator™
The only thing I've ever used is Auto-Rx as per Patman's recommendation. I'm still in the rinse phase with it, so it'll be a while until my next oil analysis.
Old Jan 22, 2006 | 06:54 AM
INTENESS's Avatar
Yea what he said,No need for that stuff and use the GC 0/30 and kn and your all set.
Old Jan 22, 2006 | 07:30 AM
vettenuts's Avatar
German Castrol here too, and Lube Control per Terry Dyson's recommendation. LC is fully discussed on the BITOG forum and is an anti-oxident. My used oil analyses have improved quite a bit since I started using it. I believe Patman may also use this but am not sure.
Old Jan 22, 2006 | 08:04 PM
nokeman's Avatar
how does this german castrol compair with amsoil. all ive ever heard is how amsoil is the best but now im hearing about german castrol for the first time.
Old Jan 23, 2006 | 11:20 AM
waiting2bl33d's Avatar
i've ran some seafoam in my crank for about a day before an oil change. that or a quart of tranny fluid to clean everything. just don't drive it hard if you use tranny fluid.
Old Jan 23, 2006 | 02:09 PM
jswelburn's Avatar
You're going to get different opinions on that question. I've been reading up for the last month or so on Oil for Ls1's, and both of these seem to be on the high end of the oil spectrum. Is one better than the other? probably. Is the difference enough to matter for the average joe? probably not.
I went with the Amsoil Euro 5w-40 and their new EaO filter because my old man is a dealer. It was also recommended by Patman. Brought the oil pressure up higher than the dino oil, and I wont need to change it for another year.
Not too bad for the 72 bucks invested.
Old Jan 23, 2006 | 07:04 PM
nokeman's Avatar
thats what ive heard...about the amsoil.
Old Jan 23, 2006 | 07:56 PM
02LS1WS6's Avatar
ok everyone...so if i go with amsoil for my 02 Ram Air...what should i get? also...get an amsoil filter or what?
