Sponsored by: CARiD
HELP Removal of Center console
Old Feb 3, 2006 | 05:25 PM
2001bluerata's Avatar
Default HELP Removal of Center console
Can't get the center console to get over the ebrake. How do you get the ebrake to go straight up?
Old Feb 3, 2006 | 09:19 PM
peterlawl84's Avatar
you gotta pull the ebrake up as high as it will go and twist and tilt the console piece...i cant remember exactly how i did it but ive taken it off several times just be patient. if you have traction control, make sure to unplug that first so it gives you alittle more freedom to move as well as the light bulb that lights up the shifter gears if you have an auto
Old Feb 3, 2006 | 10:20 PM
Ateyate's Avatar
This tells you how to do it.
http://www.installuniversity.com/ins...sity/index.htm
Old Feb 5, 2006 | 12:40 AM
Got it, Thanks guys.
Now I'm having the trouble of pulling off the bellhousing. The starter stays on right? So it's only 8 bolts right?
Old Feb 5, 2006 | 08:36 AM
kemmert's Avatar
Yep, starter stays in.... Don't forget the coupla bolts up at the top of the bell housing, easy to overlook, especially the one that you hafta get from the passenger side with a LONG extension and swivel socket after you remove the cross member and lower the tailshaft down....
