Car hard to start
I had issues about a year ago with my AC compressor pump. My AC relay went bad and my AC blew hot. There is no way to check a relay that I know of. I went thru alot to finaly find out that it was just my relay and nothing else wrong with the AC system. I had the refrig. checked done ( bought one) Nothing wrong with refrig level. Air was blowing so, nothing else wrong there, Just was not cold. Took the car to a AC shop, by the way, I'm in germany and all I got was that there was a Compressor, malfunction code. and they did not have the manual to check what that ment. 60 bucks down the drain. My PCM didn't show any codes, so I don't know what they were talking about. I decided to change out the AC compressor relay with the fuel pump relay and what due you know. The car started then shut right off. The AC relay was bad.
Anyway, I decided to buy the relays on line and when they came in, all was well. I got like five extras by mistake I think.
After doing thru a week of trouble shooting with the fuel supply issue, I decided to use one of those extra relays I got. It fixed the problem with not issues. Damn, why couldn't I have just done that first????
Has anyone else had this issue with the relays going bad, and how do you check them? If one goes bad, does that mean all should be changed out?
Hope this my help out anyone else that runs into this issue with car starting. Would suck to find out after a fuel pump change that it was only the relay. I know that the dealer would have told me that the fuel pump was bad and when they were finished charging me with that, they would tell me that you have to change out the relay with a new fuel pump.
Also, can you post a GM part number for the FP relay? And as asked above, where is it located on the car?
Thanks.....
Part number is A15 15-8571
I got mine from RockAuto since I'm overseas but you can get one from any parts store.
The relays are located in the under hood front fuse box. Pics attached.
Good luck
Made my day though and it allowed me to fix my most recent problem
