Ses Light
P0131 (M) 1/1 O2 Sensor Shorted To Ground Oxygen sensor input voltage maintained below normal operating range.
P0132 (M) 1/1 O2 Sensor Shorted To Voltage Oxygen sensor input voltage maintained above normal operating range.
P0133 (M) 1/1 O2 Sensor Slow Response Oxygen sensor response slower than minimum required switching frequency.
P0134 (M) 1/1 O2 Sensor Stays at Center Neither rich or lean condition is detected from the oxygen sensor input.
P0135 (M) 1/1 O2 Sensor Heater Failure Oxygen sensor heater element malfunction.
P0136 (M) 1/2 O2 Sensor Heater Circuit Malfunction Oxygen sensor heater element malfunction.
P0137 (M) 1/2 O2 Sensor Shorted To Ground Oxygen sensor input voltage maintained below normal operating range.
P0138 (M) 1/2 O2 Sensor Shorted To Voltage Oxygen sensor input voltage maintained above normal operating range.
P0139 (M) 1/2 O2 Sensor Slow Response Oxygen sensor response slower than minimum required switching frequency.
P0140 (M) 1/2 O2 Sensor Stays at Center Neither rich or lean condition is detected from the oxygen sensor.
P0141 (M) 1/2 O2 Sensor Heater Failure Oxygen sensor heater element malfunction.
P0143 (M) 1/2 O2 Sensor Shorted To Ground Oxygen sensor input voltage maintained below normal operating range.
P0144 (M) 1/2 O2 Sensor Shorted To Voltage Oxygen sensor input voltage maintained above normal operating range.
P0145 (M) 1/2 O2 Sensor Slow Response Oxygen sensor response slower than minimum required switching frequency.
P0146 (M) 1/2 O2 Sensor Stays at Center Neither rich or lean condition is detected from the oxygen sensor.
P0147 (M) 1/2 O2 Sensor Heater Failure Oxygen sensor heater element malfunction.
P0151 (M) 2/1 O2 Sensor Shorted To Ground Oxygen sensor input voltage maintained below normal operating range.
P0152 (M) 2/1 Sensor Shorted To Voltage Oxygen sensor input voltage maintained above normal operating range.
P0153 (M) 2/1 Sensor Slow Response Oxygen sensor response slower than minimum required switching frequency.
P0154 (M) 2/1 Sensor Stays at Center Neither rich or lean condition is detected from the oxygen sensor.
P0155 (M) 2/1 O2 Sensor Heater Failure Oxygen sensor heater element malfunction.
P0157 (M) 2/2 O2 Sensor Shorted To Ground Oxygen sensor input voltage maintained below normal operating range.
P0158 (M) 2/2 O2 Sensor Shorted To Voltage Oxygen sensor input voltage maintained above normal operating range.
P0159 2/2 Sensor Slow Response Oxygen sensor response slower than minimum required switching frequency.
P0160 (M) 2/2 Sensor Stays at Center Neither rich or lean condition is detected from the oxygen sensor.
P0161 (M) 2/2 O2 Sensor Heater Failure Oxygen sensor heater element malfunction.
If it was a shop they should have scanned the PCM and told you what code you were getting to cause the SES light.....
