Turn signal question?
Both stopped working at the same time ?
The flasher relay is by your right knee under the dash, easy to replace...
Good luck,
Rob (Bad30th)
Take off the panel under the steering wheel, the flasher relay is by where your right knee goes. It's a small metal cylinder with an "L" shaped connector on top, it will be clipped onto the metal with a small clip. Pop out old, pop in new. Done.
Rob (Bad30th)
The left and right sides of the car use the same flasher unit. The Hazards use a separate flasher unit.
The front and rear bulbs are dual filament. Its possible that the brughter (signal) filament has blown out, but the dinner filament still works.
Turn on the hazards and look for the light(s) that isn't flashing and replace it. The socket could also be the culpret. You can test that by swapping a non-working bulb with the same working bulb from the opposite side of the car to see if anything changes.
