removing manifold on 98 vette
Oil pressure sensor is bad. I have a manual on cd, but not very clear on procedure. I need to relieve fuel pressure, and disconnect fuel line as well as injector leads and some hoses. Is there a tool for disconnecting elec. lead to injectors and how do I relieve fuel pressure?
Would appreciate help.
Thanks,
btw, you dont have to disconnect the fuel lines or anything to remove the intake manifold, it will just swing over to the drivers side still connected to the lines.
edit:i guess you have a vette? should still be the same
