- Camaro General Information and Recommended Maintenance Schedule<br>Important information to help you understand your Camaro.
Browse all: Chevrolet Camaro or Pontiac Firebird Specifications & General Maintenance
Recommended scheduled maintenance
7,500 Miles
Check Oil Life Monitor. If engine oil and filter are changed, reset monitor.
Change the rear axle gear lubricant if the vehicle is used to pull a trailer or has limited slip differential
Rotate Tires.
15,000 Miles
Inspect air cleaner filter if you are driving in dusty conditions. Replace filter if necessary.
Change automatic transmission fluid if the vehicle is mainly driven under one or more of these conditions:
-In heavy city traffic where the outside temperature regularly reaches 90F (32C) or higher.
-In hilly or mountainous terrain.
-When doing frequent trailer towing.
-Uses such as a taxi, police or delivery service.
(If you do not use your vehicle under any of these conditions, change the fluid and filter every 50,000 miles (83,000 km).)
Change rear axle gear lube if it is used to pull a trailer.
Rotate tires.
22,500 Miles
Change the rear axle gear lubricant if the vehicle is used to pull a trailer.
Rotate tires.
30,000 Miles
Rotate tires.
Replace air cleaner filter.
Inspect fuel tank, cap and lines for damage or leaks. Inspect fuel cap gasket for any damage. Replace parts as needed.
37,500 Miles
Rotate tires.
45,000 Miles
Rotate tires.
50,000 Miles
If you haven't used your vehicle under sever conditions listed previously and, therefore, haven't changed your automatic transmission fluid, change both the fluid and filter. Manual transmission fluid doesn't require change.
52,500 Miles
Rotate tires.
60,000 Miles
Rotate tires.
Inspect engine accessory drive belt.
67,500 Miles
Rotate tires.
75,000 Miles
Rotate tires.
82,500 Miles
Rotate tires.
90,000 Miles
Rotate tires.
97,500 Miles
Rotate tires.
100,000 Miles
Inspect spark plug wires.
Replace spark plugs
150,000 Miles
Drain, flush and refill cooling system (or every 60 months since last service, whichever occurs first). See "Engine Coolant" in the Index for what to use. Inspect hoses. Clean radiator, condenser, pressure cap and neck. Pressure test the cooling system and pressure cap.
The services show in this schedule up to 100,00 miles should be performed after 100,000 miles at the same intervals. The service shown at 150,000 miles should be performed at the same interval after 150,000 miles.
oil change at 3,000 miles and again every 3,000 miles
rotate every 3,000 miles
start brake inspection at 9,000 miles then every 3,000 miles
at 15,000 air filter, fuel filter, battery service, oil additive, fuel additive, wiper blades, LOF, tire rotation, brake inspection, multi point inspection(belts, tires, leaks, bulbs etc..). Every 15,000 miles
at 25,000 automatic transmission flush, transmission additives, coolant system pressure test, LOF, tire rotation, brake inspection, Multi point inspection. Every 25,000 miles
at 30,000 coolant flush, coolant additives, fuel injector flush + 15k service. Every 30k miles.
at about 45k we recommend power steering flush, plus power steering additive.
at about 50k we recommend manual transmission service
at about 60k we recommend brake fluid flush, rear diff. service
at about 90k we recommend a spark plug change, automatic trans service including dropping pan and replacing transmission filter
Would you guys recommend changing at about 60k intervals?
Firebird!
Really; I would check fluids every oil change including diff., Main reason the yoke tend to leak on our cars and could burn up the diff. Sprayed all over the bottom of the car but not a drop on the ground. 60K on diff fluid sounds good if your doing it yourself ($) maybe a little longer if not. Check to see if burnt or the fluid is discolored.
