Sponsored by: CARiD
High pitched noise...?
Old Feb 19, 2006 | 10:15 PM
Rollmodel's Avatar
Question High pitched noise...?
My 2001 Trans Am WS6 recently has started making a really high pitched noise every once in a while when i am not on the gas, but when i hit the gas it will go away and come back once the rpms come down a bit, it is very annoying and i have no clue what it is. It was making a similar noise when i first bought it but the dealer where i got it said it was the A/C clutch or something and they greased it and it was fine, dont know if it could be this again or not, anyone have any ideas?
Old Feb 19, 2006 | 10:40 PM
Trev_SS's Avatar
sounds like it could have something to do with the belts
Old Feb 19, 2006 | 11:34 PM
chrisryn64's Avatar
idler pulley
Old Feb 20, 2006 | 11:33 PM
JonB's Avatar
I had/have the same problem. Mine is the a/c when I turn the a/c on it stops. It started shortly after i got it I just dripped some oil on the a/c clutch and it went away and has been gone for 2 years and has just now started again.
Old Feb 21, 2006 | 01:55 AM
95WhitetopTA's Avatar
To see if noise is in ac clutch,turn the ac on and off and see if it affects sound etc.note that when the defroster is on--so is the ac clutch.If you still can't isolate squeel,take off your belt and spin the accessories one by one to see if you have a worn bearing.By accessories I mean power steerring,alt etc.Hope this helps.
