98 z doesnt like to start
thanks
josh
hope this helps
thanks
josh
I don't know the specs on your injectors but a good rule of thumb is they should all be about the same . If one is really low it would cause your PCM to shut down and hard start or not start. It would get worse with time until you are stranded and need a tow ( I had a few of them) to fix at the dealer.I put new injectors in them and they were fine.
Now,to quickly check your injectors for leak down you have to pinch off your fuel return line and see if your fuel rail holds pressure on your gauge without bleeding down when you shut your car down. If it doesn't bleed down when you pinch it off,you have a bad fuel pressure regulator ( less costly) if it still does you have a bad injector(s).
Also have you ever replaced your fuel pump before ? I use to change them on cars about every 35k-50k at the Chevy dealer. A weak fuel pump or a clogged fuel filter could throw off O2 sensor codes because you are running lean with your low fuel pressure and the computer cannot trim your mixture enough.Try checking the above first. I hope It helps you Guys, Later
thanks
josh
-from what i heard a weak fuel pump would only give me trouble when cold...true?
