Sponsored by: CARiD
horrible bucking from a stop
Old Feb 26, 2006 | 11:50 PM
rich Z's Avatar
Default horrible bucking from a stop
On friday when accelerating from a stop the car bucked badly twice as I was letting out the clutch. I just had the same thing happend 3 times today. Before friday I have never had this happen before with any car. My car has been very low on power. I posted last week about the car would run great for a few days and then run weak. I have tested the fuel pressure, tested for vacuum leaks I have gauge inside the car. I changed the fuel filter 6 weeks ago. I cleaned the maf already, put a can of seafoam in the gas tank. I ordered new spark plugs and wires a week ago so I should get those this week. When the car bucks it feels as if the power is cutting off and then back on. What the hell is going on?
Old Feb 27, 2006 | 12:02 AM
99camarosupersport's Avatar
i think this might be the wrong place to post this type of question. try general maintenance and repairs perhaps.
Old Feb 27, 2006 | 12:04 AM
rich Z's Avatar
Ok I wil.
Old Feb 27, 2006 | 12:06 AM
rich Z's Avatar
Old Feb 27, 2006 | 12:29 AM
Z2K_MrJ's Avatar
Board Certified Idiot
Did you check your plugs and wires? or did you just order new ones? unless its major its prolly that
Old Feb 27, 2006 | 11:45 AM
rich Z's Avatar
I just checked for codes with my predator and just got a low maf code. I unplugged the connect and then plugged it back in and no bucking. Still very low on power though but I hope when I get new plugs and wires that will solve the issue since I have tested, checked and replaced everything else. The car for the past month would run strong and smooth for 4 days at the most and then all the power would suddendly go away.
