Sponsored by: CARiD
flat spot in throttle
Old Mar 2, 2006 | 09:09 PM
blackhawk J's Avatar
Default flat spot in throttle
At about 2500-3500 rpm not sure there is a flat spot in the acceleration it is only momentary but it is still annoying. Does anyone have any ideas? Should I be expecting to replace the fuel pump? Is it pulling timing? Do I need to check the air fuel ratio on a dyno? Need help...
Old Mar 2, 2006 | 09:50 PM
98 camaro's Avatar
blackhawk check out the thread "stumble" and see if it applies to your ride as well.....were trying to get to the fix
Old Mar 3, 2006 | 06:08 AM
gotcha thanks...
