Sponsored by: CARiD
coolant leak
Old Mar 4, 2006 | 07:26 PM
jimz's Avatar
Thumbs down coolant leak
small spots of coolant leaking...
after 9 hours parked at work, no problem
12 hours parked in garage, water trail follows it out.
new pump, pressure tested, no leaks?
radiator cap? clueless right now
not coming from heads, checked, and oil fine...
Old Mar 4, 2006 | 08:50 PM
CW00BlackTA's Avatar
Alrighty then! You had a leak with a water trail coming from under the car. It's not clear from that point forward. Please elaborate some so we can help you.
Old Mar 4, 2006 | 09:54 PM
myws6istheshiznit's Avatar
i had a small leak from the back of the water pump.it was very hard to find. i put on a new gasket and it was good to go. and like you said at first it would only leak sometimes. try to look around the water pump its not easy but you can spot it water leaves a stain where it leaks
Old Mar 4, 2006 | 11:40 PM
jimz's Avatar
Default elaborate
don't know what to further explain !
been pressured tested...
coolant trail in center of car when pulling out of garage
shop looked at it after drive to work, and said it was dry
asking if it could be radiator cap, which was suggested by shop
no, if leak comes from center of car, has to be pump
don't know
Old Mar 4, 2006 | 11:45 PM
jimz's Avatar
Talking
thanks...
my ws6is the shiznet
Old Mar 5, 2006 | 05:09 PM
jimz's Avatar
Default any further input?
I have a car that does'nt leak coolant...
so I guess it was an imaginery quarter gallon I put in ?
everything dry on top, coolant trail seems to be coming from mid engine...
am I the only one that has these stupid problems ?
Old Mar 5, 2006 | 07:03 PM
Hark_Z's Avatar
water pump?
Hark_Z's Avatar
edit: sorry you said you replaced it.
