Sponsored by: CARiD
Headlight motor
Old Mar 8, 2006 | 12:56 PM
93transam's Avatar
Default Headlight motor
Is there a fuse or a circuit breaker for the passenger side headlight motor somewhere? Mine quit functioning and (headlight works though) I am trying to diagnos it.
Old Mar 8, 2006 | 05:05 PM
BLKWS6's Avatar
motor is prolly dead. light will still work fine. do you know if it still makes any noise when you turn the lights on? if so....the gear in the motor is stripped. (its plastic)
Old Mar 8, 2006 | 05:16 PM
taintedmeat's Avatar
There is a fuse for each motor in the engine comparment fuse box.
Old Mar 8, 2006 | 09:37 PM
93transam's Avatar
No, no noise at all. No movement or sound whatsoever.
Old Mar 8, 2006 | 09:39 PM
93transam's Avatar
On the driver side right? Is there a schematic for the fuses like the fuse box to the left of the dash, or do I just have to go through and check them all?
Thanks
Old Mar 9, 2006 | 12:32 AM
blkbird's Avatar
Check your physical connections also. Mine were corroded and had to be replace or you could just splice and solder them together and delete the connector plug all together.
Old Mar 9, 2006 | 07:40 AM
Thanks
There are labels on the 2 fuse boxes on the driver's side, on the top of each box.
