Sponsored by: CARiD
5" Tach
Old Mar 9, 2006 | 12:32 PM
Cbrakllr's Avatar
Default 5" Tach
I just installed a 5" Auto Gage Tach in my camaro, I didnt get a Tach adapter I slpiced it into the PCM with the engine speed signal and then did all the rest. Im not getting the right reading its reading like 1300RPM less than the stock tach. Is this maybe because i didnt do the tach adapter? I think it should work just fine without the adapter. Any help is greatly appreciated.
Old Mar 9, 2006 | 01:15 PM
Weezzer's Avatar
Did you set it to accept the signal in 4 cylinder mode and not 8 cylinder mode?
The electronics of the LS1 has a type of double pulse or something like that and the shift lights have to be configured for 4 cylinder operation to read correctly.
The aftermarket tach should opperate exactly the same way.
Old Mar 9, 2006 | 01:33 PM
Cbrakllr's Avatar
Question
well i just bought the tach and installed it, is it something i need to ask for when i buy or something i can just fix? I dont understand the tach is reading 1300 under the stock tach, the shift light works just fine though.
Old Mar 9, 2006 | 05:38 PM
Cbrakllr's Avatar
Wait a second I just looked at the directions for calibrating the Tach and it says to cut wires in the back of the tach if you have 4 or 6 cylinder apps. but not 8 cylinder. So should I calibrate the tach according to the 4 cylinder application?
Old Mar 9, 2006 | 05:58 PM
NataSS Inc's Avatar
cut the wires for 4cyl operation and it will be fine.
Old Mar 9, 2006 | 10:09 PM
Cbrakllr's Avatar
Thank you soo much for the help i kno my car aint gonna blow up or anything if i dont get it workin but its jus one of those lil things that bug me, thanks.
