Sponsored by: CARiD
e-brake help
Old Mar 10, 2006 | 08:12 AM
bigti99a's Avatar
Default e-brake help
i feel that my e-brake needs to be yanked up to the sky to engage. how do you tighten this up a bit. i took a look at the rear pass brakes and i think i located the line but how do i adjust it? any help would be great guys! thanks
Old Mar 10, 2006 | 08:29 AM
01 Red WS6's Avatar
if you pull off the rear rotor there is a brake shoe. At the bottom there is a little part with a gear looking thing . Spin that part and it should spread the shoe open. It's pretty easy once you look at it
Old Mar 10, 2006 | 10:52 AM
2001NBMZ28's Avatar
Have you tried setting it slowly 3 or 4 times in a row?
Old Mar 13, 2006 | 09:12 AM
bigti99a's Avatar
thanks. i have tried to pull it slow to see if it would start to tighten. no luck there. any other suggestions? it seems like i'll be pulling the rotor. thanks for the help.
