Sponsored by: CARiD
Wierd coolant problem
Old Mar 17, 2006 | 08:17 AM
777's Avatar
777
Default Wierd coolant problem
Well my car's radiator is filled to the top, but after awhile the low coolant light comes on. I know it's full because if I take the cap off and let the car get hot enough for the fans to come and run the heater the coolant is still at the top, however, the low coolant light comes on. Or at least that's what I think it is. The little rectangle thing with a wavy line in the middle and a hole at the top. I think my neighbor is having the same problem. What's the deal?
Old Mar 17, 2006 | 08:23 AM
99FormulaM6's Avatar
i know on LT1s the sensor would always go bad. maybe thats it. i assume it is
Old Mar 17, 2006 | 08:36 AM
777's Avatar
777
Oh ok, so just a new sensor. It's wierd though because it will go off and on. Like once the car warms up some it will kick on.
Old Mar 17, 2006 | 09:47 AM
yea, probably the sensor.
its like 40 bucks i think, but you can just unplug it if you want. it wont set any codes or anything. just watch the coolant level
Old Mar 17, 2006 | 09:54 AM
DSG's Avatar
DSG
I agree the Sensor is prolly bad. Just unplug it and the light will go off.
Old Mar 17, 2006 | 10:18 AM
777's Avatar
777
Ok, because I'm not about to spend $40 on a sensor that really doesn't do anything. Thanks guys. You will know when you don't have enough coolant anyhow because the water temp will be high and mine is always really low.
