Sponsored by: CARiD
Stock Volt Gauge
Old Mar 19, 2006 | 12:57 PM
2001NBMZ28's Avatar
Default Stock Volt Gauge
I put an Optima red top in my car a few weeks ago and now every once in a while my volt gauge will dip to just below 13 for a couple seconds, then bounce right back to normal. Sometimes happens when cold (thinking air pump cycling maybe?) but sometimes when fully warm at 50 MPH. Never did it before - does this mean I'll be buying a new alternator soon? Car only has 23K on the clock.
Old Mar 19, 2006 | 01:54 PM
Z28LS1camaroguy's Avatar
no its does that when im sitting at a stop light for awhile waiting for it to change, but only does it at night when my headlight and all that is on. A4 have a low idle and when sitting there the volts will go down b/c of the low idle, im planning on getting a ASP underdrive pulley along with there overdrive pulley to see if that helps out the volt issue.
Old Mar 19, 2006 | 02:38 PM
2001NBMZ28's Avatar
So maybe I'm just seeing the voltage regulator working through the gauge? Shouldn't be an idle problem for me, my in gear idle is set to 760. I might try removing the air pump fuse for a few days and see what happens - if it doesn't stop at least I can eliminate the pump draw.
Old Mar 19, 2006 | 02:48 PM
my car idles at 750 RPMs, do you have a system or any aftermarket electronics??
Old Mar 19, 2006 | 03:13 PM
2001NBMZ28's Avatar
No system, only thing extra is two small LEDs wired to my SLP fan switch so I can tell when the fans are on - they're working fine with the car on or off. Maybe I'm just being paranoid and never noticed it before.
Old Mar 19, 2006 | 03:22 PM
most likely and plus the stock voltmeters arent that reliable anyway.
