Sponsored by: CARiD
need horn help...
Old Mar 20, 2006 | 09:47 PM
THE LAST Z's Avatar
Default need horn help...
I really need to push my steering wheel hard to get my horn to work. is there a horn pad behind the air bag that i can replace or adjust?
Old Mar 21, 2006 | 12:31 AM
ZeeQuick's Avatar
I'm in the same boat here....sometimes I need to push hard on it three or four times before I get the horn to sound.
Old Mar 21, 2006 | 06:03 AM
Swedez28's Avatar
Same problem here too. Have to hit it just right to get horn to sound! GRRRRRR!
Some one hopefully will chime in and help us all.
Old Mar 21, 2006 | 10:08 PM
THE LAST Z's Avatar
I orderd a horn contact from the dealer. $10...we'll see how it goes.
Old Mar 22, 2006 | 01:44 PM
lo_jack's Avatar
Might not be the contact in the wheel...those horns are "adjustable" via a screw that changes the resistance of each horn...eventually they get jacked up/out of whack...could be that. I tried to "adjust" mine once when they stopped working well...they became so non functional I cut them both off and switched to 80's dodge truck horns.
Old Mar 25, 2006 | 04:56 PM
THE LAST Z's Avatar
I just replaced the contacts. It worked better, but i was not satisfied.
The airbag hits the contacts, and the contacts hit the wheel when you press it.
I made little plastic spacers and stuck them with double sided tape, on the outside of the contacts. This makes a shorter distance between the contact, and now you dont have to press it so hard.
I didnt see any adjusting screw...
Old Mar 27, 2006 | 02:41 PM
lo_jack's Avatar
Screw is on the horn itself in the front left passenger nose area under the battery, accessed from below. There is a thread about that nearby by The Interceptor.
