Sponsored by: CARiD
Cruise control / throttle problem, URGENT HELP NEEDED
Old Mar 29, 2006 | 01:23 PM
Savage Messiah's Avatar
Default Cruise control / throttle problem, URGENT HELP NEEDED
so since my cruise never worked I was just taking it out for weight reduction purposes... unbolted it all, unplugged the electrical connector, and went to unplug the cable. Now keep in mind my car has 2 separate throttle cables, one for the pedal and one for the cruise. After fighting with it for about 45 min I decided F it I'll just cut the cable... cut through the insularion with wire cutters, then cut through the outer wires with a huge pair of sheers... well actually I was cutting and the pulled on it, heard some cracks and felt a bunch of slack. I look and see that I pulled it off of all the plastic clip that hold the cable from the module to the firewall (clips holding it onto the master cylinder and holding it right over the TB remained intact). I pulled the cable at the module and the outer wires popped out. Went with the sheers and tried cutting through the inner insulation and wires, didnt get anywhere, maybe cut 2 or 3 wires in the whole bundle.
I then decided to start the car to make sure everythings fine... and now it's acting like the throttle is stuck open. Revving to 4k smacking the limiter and keeps trying to rev. I put it in neutral, same thing. Naturally and logically I did not put it in drive or reverse. Plugged in the electrical conector, same thing.
So now my question is WTF?!?!?!?! Is is possible I broke something like the throttle position sensor or something else? Was the tightness in the line necessary to keep the throttle closed, and now that there's slack it flys open? I'm completely clueless here and need to fix this problem ASAP. PLEASE help... respond here, or IM me on AIM at MoPMoonchild... thanks...
Old Mar 29, 2006 | 01:39 PM
also, even only running for a few seconds, it smells REALLY freakin rich
Old Mar 29, 2006 | 03:16 PM
well!!
I just went out and pulled the throttle PEDAL cable at the TB, the little rotating thingamabob snapped back but on a hunch I went to see if I could push it close any more... I did and it worked. woohoo! (i hope this is it)
