Sponsored by: CARiD
Alarm remote programming
Old Apr 3, 2006 | 08:38 PM
RobLS1's Avatar
Default Alarm remote programming
I wondering if anybody know how to program a remote to work with my stock alarm on my 2000 Trans Am
Old Apr 4, 2006 | 04:04 PM
JEB Garner's Avatar
Wink
Get a manual for your car. It tells you how to program the unit. No Manual or can't find one? Go to your local dealer and ask for them for the directions on how to program your remote to your alarm system. They should be able to supply you with a copy of the Programing procedure for Your Factory Alarm System right out of their shop manual.
Old Apr 4, 2006 | 04:17 PM
WhiteRhino's Avatar
I saved this along time ago,
Thread: Frequently Asked Questions View Single Post
#22 12-03-2005, 11:35 AM
2MuchRiceMakesMeSick
Stereo&ElectronicDirector Join Date: Apr 2004
Trader Rating: (0)
Reprogramming Another Keyless Entry Remote
Thanks to jimbonzzz
Each remote keyless entry transmitter is coded to prevent another transmitter from unlocking your vehicle. If a transmitter is lost or stolen, a replacement can be purchased through your dealer. Remember to bring any remaining transmitters with you when you go to your dealer. When the dealer matches the replacement transmitter to your vehicle, any remaining transmitters must also be matched. Once your dealer has coded the new transmitter, the lost transmitter will not unlock your vehicle. Each vehicle can have a maximum of four transmitters matched to it. Have each transmitter you intend to match ready for the next steps. To match transmitters to your vehicle, do the following:
1. Turn the ignition key to RUN, then to OFF. This will disarm the content theft-deterrent/alarm system (if equipped).
2. Remove the RADIO fuse. This fuse is located in the main fuse block which is located on the left side of your instrument panel. See “Fuses and Circuit Breakers” in the Index.
3. Turn the ignition key from OFF to RUN three times quickly (within five seconds). The vehicle will respond by locking the doors, unlocking the driver’s door and releasing the hatch. Your transmitter is now ready to match the vehicle. Leave the ignition in RUN.
4. Press and hold the LOCK and UNLOCK buttons on the first transmitter for 15 seconds. The vehicle will respond as in Step 3.
5. Repeat Step 4 for the remaining transmitters.
6. When you have finished matching all of your transmitters, replace the RADIO fuse.
7. Check that all transmitters work by pressing the buttons. If the transmitters don’t work, or if you’d rather not match the transmitters yourself, see your dealer.
__________________
Soon To Be TT
View Public Profile
Send a private message to 2MuchRiceMakesMeSick
Find all posts by 2MuchRiceMakesMeSick
Add 2MuchRiceMakesMeSick to Your Buddy List
Old Apr 4, 2006 | 04:39 PM
2001NBMZ28's Avatar
4th gen owners manuals - http://shbox.com/pdf/manuals.html
