Sponsored by: CARiD
Leaky T-top
Old Apr 4, 2006 | 07:07 PM
transAm-98's Avatar
Default Leaky T-top
Does anyone know where the best place to get new seals fot T-tops, and about how much they run. mine have been leaking all over me and my interior with all the rain we've been getting lately.
Old Apr 4, 2006 | 07:34 PM
waiting2bl33d's Avatar
dealer and ebay are the only 2 i know
Old Apr 4, 2006 | 08:01 PM
mrhzk35404's Avatar
maybe gmpartsdirect
Old Apr 4, 2006 | 09:55 PM
nickls1's Avatar
They run a lot unless you get used ones. Even if you get used ones from a junkyard youre taking a gamble. Have you tried to clean and grease them? It may sound dumb but if you havent done it and they are not torn, a tube of dielectric grease is less than 5 dollars and the new rubber is a few hundred.
Old Apr 5, 2006 | 03:21 PM
ins0mnia24's Avatar
You sure the drain holes going down each pillar on the front isnt clogged??
there is 2 or 3 drain holes on each side of the front of the car going through the rubber along the pillars.
Take ur t-tops off then take a little cup of water and pour them down each hole and see if the water runs out near your door hinges if not then they might be clogged.
Also does any of the weather stripping lift up off the metal of the roof?? you might be able to just reapply some kind of glue to get a tight seal in between the weather stripping & top of the car
Old Apr 5, 2006 | 05:15 PM
transAm-98's Avatar
thanks for the info, i'll have to check everything out if it ever stops raining
