Why did I visit the rev limiter....?!
You'll notice the difference in the Type F. I'll try to tell the short version of when I put it in. My wife and I were headed to LA from Vegas and were going up the Baker grade on I-15. I was running around 90 mph. All of a sudden smoke started coming up thru the E-brake handle and it smelled sweet. I pulled over and thought maybe an electrical fire because I had just put in some stereo equipment, but that didnt explain the smell. The car was running fine and all the gauges were good.
So since it came from the E-brake area I checked the tranny fluid. It was burnt pretty bad. I called my Dad and asked him if there was any thing I could temporarly do. He said take it to a shop and have them swap it out to Type F. At first I thought he was crazy. This was in 01. Even though my tranny slipped, and I would have to manual shift it sometimes. I even went to the track a couple of times I just got my tranny rebuilt a little over a month ago 06.
I came on this site and found out that alot of people run it. I wished I would of took pics of my bands. They were burnt up pretty good. Basically Type F has a grittier blend if you will. So it helps prevent the slipping.
Sorry for the ramble! I just wanted to put out there why I started using it.
i assume it only did it once, though? since it doesn't sound like it even tried to shift, and if it hasn't done it again, you may be in luck for now. could be some trash floating around that got stuck in an orifice, or a sticking solenoid (but the solenoid should throw a code IIRC). you might consider flushing the fluid, although some will disagree.
I will probably try to get the levels right though. I'm still not really sure what to think about whether its going to last or not. Only time will tell.
Assuming it did take a dump on me what am I looking at for a rebuild ? Is it even worth rebuilding ? and if its not whats my next best option ? I do plan on putting more power in it in the future (Heads / Cam) so maybe a built tranny when this one dies?
Opinions ? Transmissions is an entire world that I am pretty unfamiliar with
Edit: on a side note it has been much warmer here the past few days (warmer streets = better traction) I haven't had traction problems dropping to first today and haven't hit the rev limiter either (I tested it ALOT!
)Hopefully that is a good sign for me
Ski
