Sponsored by: CARiD
how to remove u-joint?
Old Apr 12, 2006 | 08:01 PM
circusboy's Avatar
Default how to remove u-joint?
it looks there are some pins holding the u-joint in do i just remove them and take the u-joint out? or is more complicated
Old Apr 12, 2006 | 10:14 PM
ZeeVert's Avatar
Not sure what you're refering to. Do you have the drive shaft out?
Old Apr 12, 2006 | 11:06 PM
circusboy's Avatar
i did have it out. it's back in now. the u-joint was ok. i was going to replace it because i had the driveshaft out.
the part of the shaft that the u-joint goes in has little pins on top and bottom. they are about an 1/8" in diameter. i thought i had to pull them out and then press or beat the u-joint out.
Old Apr 12, 2006 | 11:26 PM
ZeeVert's Avatar
You were probably were seeing the plastic tips from the injected plastic retainer. I didn't realize that they were still used on u-joints. Basically, it is a cheap and reliable way to retain the bearing cups in high production, instead of various types of C-clips and snap rings. The replacement u-joint comes with the appropriate retainer.
It's been a few years since I had to replace a u-joint, let alone one with plastic retention. I understand that the method I used is not an approved procedure. There are probably instructions that can be found with a web search if you ever need to replace one.
Old Apr 13, 2006 | 06:37 AM
circusboy's Avatar
thank you for the helpful info.
Old Apr 13, 2006 | 07:11 AM
1QUIKWS6's Avatar
Active Streak: 30 Days
I used a propane torch to gently heat the yoke ends with the injected plastic retainers till the plastic melted out - freeing up the U-joints to be removed.
Don't overheat the yokes with the torch - the plastic should melt out rather easily.
Don't know if this is the recommended procedure either - but it worked just fine...
-Jay-
Old Apr 13, 2006 | 09:45 PM
daryl2cb@yahoo.com's Avatar
they look like those gay snake fireworks, LOL that is what is reminded me of when I did mine
