Rattle - could it be IN my Y pipe?
I swear I have tried to tweak every damn heat sheild under the car and nothing seems to help. Could it be something INSIDE the offroad Y pipe? Any other suggestions appreciated!
After posting this I went on another expedition. I loosened up my Y pipe with the idea of pulling it loose to inspect it. As it turned out I didn't have enough time to go all the way and pull it completely loose. So instead I started it up with the clamps loosened up to see if the "note" of the rattle would be different - it wasn't.
Since I ran out of time I gave up and retightened the Y clamps. I went ahead and oiled the clamps with just a few drops on the bolts to keep them from siezing. I also tried messing with the heat shields running along the fuel lines on the driver side. I squeezed some old rubber between the shield and the car to make sure there was no play in it so it couldn't rattle if it wanted to.
Apparently it must have been one of those things. Now the rattle stopped but instead it is now squeeking! I think it must be the rubber squeeking but not sure. It is a much better sounding than the rattle but still annoying....guess I'm homing in on it but didn't get if completely handled yet. I'll try to update when I figure it out completely.
