Sponsored by: CARiD
Need Help Bad
Old Apr 24, 2006 | 01:22 AM
madmatt97's Avatar
Default Need Help Bad
I have a 1997 lt1 camaro im trying to get the hub off the crank. The bolt that holds the hub on just spins like its stripped and will not come out. If its stripped how can i get it out? do i torch it out? or try an air hammer on the back side of the hub will someone uses a impact gun on the bolt and just hope it catches threds? or I might have to pull the motor just put this fuc*er in about 5 months a go. all because of a FUC*ING elec water pump by CSR 3rd one less then a year CSR sucks so i went back ro stock. I Have to replace a bad opti (4th one in the last year all brand new ones but first one that actualy got wet 2 others were aftermaket keep acdelco fit and well kinda lasted longer) and I just wanted to replace the seal to the hub since i was in there and it leaks alittle. let me now what i can do. let me now what u guys and girls now/ think how to get it off. thnks matt
