Sponsored by: CARiD
Oil filter question
Old Nov 2, 2002 | 11:28 AM
OfficerZ28's Avatar
Default Oil filter question
I use Mobile 1 oil, but i dont do it myself. i looked underneath yesterday, and noticed it had a short filter on it. When you guys say get a long filter, what filter are you talking about? Does it make a difference in how long the oil lasts?
What size/brand filter should i be using with mobil 1?
How many miles can i go with mobil 1? I've had it in about 6k miles now since my last oil change.
Old Nov 2, 2002 | 11:57 AM
Fahad's Avatar
Default Re: Oil filter question
The size filter is 44 , you can using many oils differences like visco 5000.
The miles with mobile 1 maybe between from 6000 to 8000 km.
Best of luck.
Fahad..
Old Nov 3, 2002 | 12:09 AM
35THSSLE's Avatar
The "longer" LS1 oil filter I use is the Mobil 1 M-206. The standard size I believe is an M-107
Hope that helps...Alex
Old Nov 3, 2002 | 05:01 AM
Patman's Avatar
The longer filters will flow more oil, hold more dirt before plugging and will also go into bypass mode much less (especially when the oil is cold)
With Mobil 1 you can easily run it much longer than 3k. Many people go to 10-15k intervals with good results. My comfort zone is 10k, although I know for a fact that in a good engine (one that is mechanically sound) this oil can go longer and still provide excellent protection.
