Sponsored by: CARiD
Turn Signals
Old May 6, 2006 | 07:52 PM
fireman99TA's Avatar
Default Turn Signals
Ok so my turn signals will not work yet my hazards will. I have checked my fuses and everything seems fine. This just happened yesterday. Anyone have any suggestions?
Old May 7, 2006 | 08:44 AM
Duffster's Avatar
either signal relay or both blown.
signal relay typically just under knee pad to the left of the stereo.
Old May 7, 2006 | 12:59 PM
Signal relay hmmm....ok i will check it out and see what i can find. Thanks
Old May 7, 2006 | 03:27 PM
VIP1's Avatar
Copy & Paste Moderator
There are two flashers:
* One is for the hazards
* The other is for he left/right signals
Turn on the hazards and look for any bulbs that are not flashing (that are supposed to flash) or flashing irreguarly. Inspect that bulb and its socket. Replace the bulb or clean off the socket's corrosion (which ever is needed). If all the bulbs appear to work properly, replace the signal flasher.
Old May 8, 2006 | 08:07 PM
Ok the lights all work at the right speed. I will be changing out the singal flasher. Hopefully that will work. Thanks...
Old May 8, 2006 | 08:12 PM
smg267's Avatar
Hey this just happened to my Z the other day right before I put my clear corners in. One of my bulbs was burnt out in the front turn signals. The flashers worked when i put the 4 ways on but not when I used the turn signal. My Dad has a 02 WS6 and he is always going through turnsignals. I guess they had shitty wiring. He replaced both sockets. Everytime it gets wet out he looses one.
