Sponsored by: CARiD
Shudder
Old May 18, 2006 | 06:14 AM
freshduckie's Avatar
Default Shudder
2001 ws6 m6 52,000 miles bolt on mods.
I changed my plugs and wires about 7,000 miles ago and ever since I have this shudder upon low rpm accleration. So I want to check the plugs and wires. Is there a easlier way then just replacing everything again. I heard something about removing one wire at a time to test them, hows this work excatly, advice?
Another thing I don't get any code on the dash, should I if there is something wrong with the plugs/wires?
Thanks alot
Old May 18, 2006 | 01:34 PM
Anyone?
Old May 18, 2006 | 05:30 PM
MJK's Avatar
MJK
If you are getting an actual misfire it should put out a code...
I'm sure you have but,its worth mentioning.Have you double checked all the plugs and wires to make sure nothing popped off?Sometimes a wire can look as if it is still on when in fact it never snapped in.
I have also seen plugs back off if the didn't get torqued properly..
If it wasn't doing this before the swap,I would test each wire by swapping one new wire at a time with the old ones...If it is the wire/wires you should hit it sooner or later by doing this...or in the process find a problem with a plug or something...Also double check your gaps as you go.
Just a couple of ideas man...Good luck
Old May 19, 2006 | 11:33 AM
Yeah I thought I double checked everything well enough a while back, I hope I don't have to end up doing a complete swap of plugs/wires again trying to find out the problem. I am tossing around the idea of see if I have a bad fuel pump.
Old May 19, 2006 | 02:15 PM
MJK's Avatar
MJK
Personally,if I had the choice between the fuel pump (and all involved in swapping one...) and swapping out the wires...I would REALLY prefer to go after the wires first...
Old May 22, 2006 | 10:23 AM
Well I checked the fuel pressure and its fine, I think maybe I should check the timing, what do you all think?
