Sponsored by: CARiD
not charging!!!
Old May 19, 2006 | 06:56 PM
Iam2bewit's Avatar
Default not charging!!!!!!
car wasn't charging, so i brought a new aternator and battery. Still not charging, and Ideals?
Old May 19, 2006 | 07:30 PM
2K2WS6TA's Avatar
Check the exciter wire at the top of the alternator, also check the guage is accurate
Old May 19, 2006 | 07:59 PM
FlamingChicken's Avatar
I had a charging problem recently. finally after trying everything i thought was wrong i took off the positive terminal and it was corroded. cleaned it and the ground beside it (i have a 95, may be different on ls1) and no charging problems since.
Old May 19, 2006 | 10:05 PM
staringback05's Avatar
when u start the car up take the battery cable off, i know this works with my s10....if ur cars holding its own charge and ur alternator is good, it wont cut off....if it does then u know whats up....and yea like the other guys said check the terminals, might have to bust out some coke cola...
