Sponsored by: CARiD
headlight bouncing
Old May 21, 2006 | 02:40 PM
Fingerly's Avatar
Default headlight bouncing
Ever since i have had my Trans am the passenger headlight will boune up and down on the highway. After some hunting i figured out where the play was. The headlight arm that raises and lowers the light is loose where it connects to the headlight assembly. The two metal washers that hold it on have pulled away. I have tried to force them back with no luck on getting them to stay in place. Any ideas on how to fix this? Can i just buy new washers?
Old May 22, 2006 | 05:57 PM
Viper's Avatar
Make the pic smaller, I can't see **** in that photo.
Old May 24, 2006 | 08:52 AM
johnpate01's Avatar
I second that, cant see anything. Blurry too.
Old May 24, 2006 | 08:55 AM
Second_Infinity's Avatar
Made the image smaller...
Old Jan 22, 2007 | 01:32 PM
toofast99's Avatar
Did you ever get this fixed? My car has the same problem...
Old Jan 24, 2007 | 10:16 PM
nick1ta's Avatar
Default headlights annoying on my 2000 ram air!
I also have a headlight porblem, but my headlights go up and down when I unlock and lock the car(with or without the remote). WTF? PLEASE SOMEONE HELP!!!!!!!
Old Jan 24, 2007 | 10:26 PM
1999Transamman's Avatar
Nick:
why is there a "noise" when you lock/unlock the doors, when the headlights are turned on/off , or why do my headlights come up when I just turn on my park/fog lights.
The headlights on the Trans Am/Formula/Firebird measures amperage (resistence) to know when the headlight is fully up and fully down. When a plastic gear in the headlight motor gets stripped the system keeps powering the motors and thats why you hear a jackhammer/grinding type noise when you lock/unlock the doors or when you turn on/off the headlights.
There are two options to solve the problem.The first is the 180 temp fix, this when you rotate the gear in the motor to the unused portion. The gear in the motor only uses half of a side to raise/lower the lights, so you have another half of the gear that has never been used. The second is to replace the plastic gear that has worn out with a brass gear.
