Sponsored by: CARiD
oil and coolant lights?
Old May 23, 2006 | 08:31 PM
mbtransam's Avatar
Default oil and coolant lights?
I have recently acquired a frequent low oil and low coolant light in my dash. They started at different times, and are off and on. Other than the sending units, is there anything else that might cause this (yes the levels are correct).
Old May 24, 2006 | 12:39 AM
staringback05's Avatar
they might just need to be reset, i cant remember how its done....or the sending units could be bad...the one of the back of the manifold or the one down by the pan...u could also take this ? to the mant. department
Old May 24, 2006 | 12:56 PM
2001NBMZ28's Avatar
The low coolant sensors are known for going bad, most people just disconnect the sensor wires and tie it off to keep the light from coming on. Think they did away with them on our cars in 2K, mine doesn't have one. It's on the passenger side of the radiator, about 4-5" below the radiator cap. The low oil level indicator screws into the passenger side of the pan, if it was me I'd replace that one if the level is consistently correct when it comes on.
Old Jul 3, 2006 | 01:21 PM
quickgoldls1's Avatar
to reset computer turn key on but not started pull fuse pcm ignition and pcm battery turn key off wait 15 sec. and replace fuses. code should clear. if not then replace the sensors
Old Aug 25, 2006 | 07:30 AM
kapedogg's Avatar
I'm running into the same problem all the sudden. Went to the track last weekend. Coolant light came on the next day. Low oil light came on this morning after starting her up. Both levels are actually fine though. Never have reset after oil changes, so I'll try that and see what happens. Seems odd that they both started going crazy together.
