Sponsored by: CARiD
engine check codes 26,27 and 77
Old May 24, 2006 | 06:52 PM
bob-95-firebird's Avatar
Question engine check codes 26,27 and 77
My 95 Firebird 5.7L engine check light has come on and I have retrieved the codes and they are listed below:
26 – Evaporative Emission canister purge solenoid value circuit
27- EGR – vacuum control signal solenoid valve circuit
77- Cooling fan #1
I have replaced the ERG solenoid.
Dose anyone know what I should replace based on these codes?
Thanks
Bob
Old May 24, 2006 | 11:04 PM
01RedT/A's Avatar
sounds more to me like you need to check power and ground to these circuits. doesnt seem like anything is broken per say, just not getting the proper signals..
Old May 25, 2006 | 10:27 AM
waiting2bl33d's Avatar
the fan one. have you checked your fues? OBD 1 is so hard because it could just be something relative to those codes not exactly what the code is saying.
Old May 25, 2006 | 01:45 PM
The fan fuses keep on blowing I have looked at the circuit but I could not find any wiring problems. I was thinking about installing a fan switch, if anyone has had this problem I would like to hear how you fixed it. What do you think about installing the manual switch?
