Sponsored by: CARiD
need help quickly
Old May 29, 2006 | 12:55 PM
slammin86's Avatar
Default need help quickly
alright, on GTO's you can pull the ECU fuse go inside the car and click the key to the on position. then go back and put the fuse back in and it resets the ECU how do you reset the ECU on an 02 F-body?
Old May 29, 2006 | 01:33 PM
2001NBMZ28's Avatar
Turn key on, don't start car. Pull PCM BATT and PCM IGN fuses in engine compartment. Wait 5-10 min. Turn ignition off. Replace fuses.
