Starter Problem?
any idea if this is a sign of a failing starter or something else? perhaps the battery (although the battery seems fine)
When it does it next time hold the key in the start position and have a friend tap the starter with a blunt tool and if it starts I would say starter. If this works it normally is the solinoid on the sarter that gets arcing marks on the disk that cause a bad connection.
It could be alot of things but the way this sounds I would have the starter tested.
