Sponsored by: CARiD
Weird Electrical Problem
Old Jun 6, 2006 | 11:21 PM
Ditmeion's Avatar
Default Weird Electrical Problem
I seem to have developed this problem after my head & intake swap...not sure if there is a connection or not...
Everytime I try to start my car, it barely turns over (but does start), then the radio clock & trip odometer resets.
Battery is only 6 months old (red top optima) ...cables are tight...tested resistance between top posts & side post where cables attach to battery...good
Battery has about 12.5 Volts when car is off
Everything looks fine...I guess I can take the battery up to Autozone to have them test...battery has been on a battery tender ever since I bought it & has this starting problem even after charging for a few days.
Anyone ever had this problem?
TIA
Old Jun 7, 2006 | 07:17 AM
FL01SS's Avatar
Possibly a loose ground wire?
Old Jun 7, 2006 | 08:49 AM
Ditmeion's Avatar
Are you referring to the ground wires on the back of the driver side head?
I did put all of them(3) from 2 bolts onto one, by suggestions from this web site...if it is tight, could that be possibly the problem?
