Sponsored by: CARiD
Water pump weep hole?
Old Jun 7, 2006 | 12:49 PM
LS1PoweredZ28's Avatar
Default Water pump weep hole?
Can someone explain to me where the "weep hole" is on the water pump? I have a small leak since I put my motor back together and from what I have been reading its either the gaskets (relatively easy fix) or the weep hole (new water pump ).
Thanks guys,
Kevin
Old Jun 7, 2006 | 01:04 PM
1LoudTA's Avatar
should be right by the pulley on the neck of it. sometimes one on the bottom and one on the top, get a mirror and try to look for it from different angles, if theres a stain around it thats whats leakin then u need a new waterpump, if you had the waterpump layin on the pulley while it was off the car you probably screwed up the bearing b/c theyre only designed to have pressure put on the bearing from the belt, not an inward pressure if that makes sense to you
Old Jun 7, 2006 | 01:16 PM
Thanks a bunch 1LoudTA, I'll have to take a look when I get home. I don't know where its leaking from yet, it was too dark for me to find the source last night. Hopefully its just a leaky gasket.
Kevin
Old Jun 7, 2006 | 01:28 PM
2002_Z28_Six_Speed's Avatar
What you heard is right.
Old Jun 8, 2006 | 12:01 PM
I took the pump off yesterday and I still don't see the weep holes . But the leak seems to be coming from around the pulley so I guess its time to replace it.
Thanks for the help guys,
Kevin
