Sponsored by: CARiD
help me fix my a/c
Old Jun 13, 2006 | 04:54 PM
alexc's Avatar
Default help me fix my a/c
its on my moms 99 chevy venture w/ the 3.4 l v6. there was no cold air coming out of the vents but the compressor was running so i figured it needed refrigerant. so i put 2 cans of refrigerant and everything is working fine again. a couple days later my mom calls me and tells me the a/c isnt working again. i check it out and now the a/c compressor doesnt even turn on. what do u guys think???
Old Jun 13, 2006 | 05:32 PM
2001NBMZ28's Avatar
Compressor won't come on if the pressure is too low/high. Assuming it was low before you added refrigerant look around the connections and see if you can find any oil leaking. Don't think F-bodies throw a SES light for AC, but are stored in the PCM - probably the same on a Venture.
Old Jun 13, 2006 | 06:29 PM
victimizati0n's Avatar
sounds like it is leaking out.
I had the same problem, but I just went out and bought a whole bunch of AC seal crap, and so far it hasnt happened again
