Sponsored by: CARiD
SES light blown?
Old Jun 17, 2006 | 04:35 PM
Bahlord's Avatar
Default SES light blown?
Real new here.
My car's been running real rough for a few days now. After a few minutes of driving it starts to get a misfire/hesitation/bumpy jerk at 2k rpm to about 3k or more, but the SES light wasn't on, so I've been reading things here and replaced my front o2 sensors, I just noticed that when I turn the key on when all the dash lights come on, the SES light doesn't, I thought it did? Am I right? (And if it is a blown light, how hard is it to change?) Also, any other suggestions on what my misfire/hesitation wierd problem is? (No recent mods.)
Thanks in advance.
'99 Trans Am
Old Jun 17, 2006 | 04:46 PM
2K2WS6TA's Avatar
The bulb is blown, it's supposed to light up when you first turn the car on, AFAIK to change it you need to take the gauge cluster out, and look for the bulb on the back
As for your problem, check the plugs and wires first, the fuel filter, and the fuel pump
Old Jun 17, 2006 | 05:19 PM
2001NBMZ28's Avatar
Yeah it should light up turning the key on. If it's still acting up take the car to Auto Zone or someone who can read the codes - I'm thinking they'll still be there even if the SES bulb doesn't illuminate on the cluster. If you have any stored codes post them so we can help. And welcome to the board.
Old Jun 17, 2006 | 05:39 PM
Bahlord's Avatar
Default Thanks
Thanks for the prompt help guys, i'm going to get it scanned tomorrow and post codes if it sees any. And see about getting the light changed.
Thanks again
Old Jun 17, 2006 | 09:36 PM
Bahlord's Avatar
Ok, now it's wierd, the SES light is working again? When they went to scan the codes and turned the key it turned on then off, and my car wasn't throwing any codes, should I still try plugs and wires? How do you go about checking fuel pressure to see if it's the fuel pump? I changed the filter a few days ago.
Thanks
